Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
  • Oplysning
    Windows 11
    Find ofte stillede spørgsmål og svar her.
Funktioner
Indlæser...
HP Color LaserJet Pro MFP M182-M183 Printers - Replacing Toner Cartridges
This document is for HP Color LaserJet Pro MFP M182n, M182nw, and M183fw printers.
To replace the toner cartridge, open the toner cartridge door, remove the old toner cartridge, and then install the new toner cartridge.
bemærk:
The imaging drum is integrated into the toner cartridge. To replace the imaging drum, you must replace the toner cartridge.
Replace the toner cartridge
If a toner cartridge is empty, replace it with a new, genuine HP toner cartridge.
  1. Open the toner cartridge door.
    Opening the toner cartridge door
  2. Grasp the blue handle on the toner cartridge drawer, and thenpull out the drawer.
    Pulling out the toner cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull thetoner cartridge straight up to remove it.
    Removing the toner cartridge
  4. Remove the new toner cartridge package from the box, andthen pull the release tab on the packaging.
    Pulling the release tab
  5. Remove the toner cartridge.
      advarsel:
    Do not touch the imaging drum on the bottom of the tonercartridge. Fingerprints on the imaging drum can cause print qualityproblems.
    Removing the toner cartridge from the packaging
  6. Grasp both ends of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    Gently rocking the toner cartridge back and forth
  7. Insert the new toner cartridge into the drawer. Make sure the color chip on the toner cartridge matches the color chip on thedrawer.
    Inserting the toner cartridge
  8. Push the toner cartridge drawer into the printer.
    Pushing the toner cartridge drawer
  9. Close the toner cartridge door.
    Closing the toner cartridge door
Review the list of frequently asked questions about replacing the toner cartridges.
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
