Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
  • Oplysning
    Lær hvordan du kan opgradere til Windows 11
    Windows 11-opgraderingsvejledning.
Funktioner
Indlæser...
HP OfficeJet Pro 9010, 9020 Printers - Replacing Ink Cartridges
This document is for HP OfficeJet Pro 9010, 9010e, 9012, 9013, 9014, 9014e, 9015, 9015e, 9016, 9018, 9018e, 9019, 9020, 9020e, 9022, 9022e, 9023, 9025, 9025e, 9026, 9028, OfficeJet 9012, 9012e, and Premier All-in-One printers.
This document contains steps for replacing the ink cartridges.
Replace the ink cartridges
Replace any low or empty ink cartridges.
  1. Turn on the printer.
  2. Open the ink cartridge access door.
    The carriage moves to the center of the printer.
  3. Wait until the carriage stops moving before you continue.
  4. Push in on the front of the ink cartridge to release it, and then pull it toward you to remove it from its slot.
    Image: Remove the ink cartridge from its slot.
  5. Remove the new ink cartridge from its package.
  6. Hold the new ink cartridge so that the ink cartridge contacts face the printer.
  7. Slide the new ink cartridge into its slot, and then gently push it forward until it snaps into place. Make sure the letter on the ink cartridge matches the letter on the slot.
      advarsel:
    Do not lift the latch handle on the carriage to insert ink cartridges. Doing so could cause the printhead or ink cartridges to be incorrectlyseated, which could damage the print mechanism and cause printing problems.
    Image: Insert the ink cartridge into its color-coded slot
  8. Repeat these steps to install any other new ink cartridges.
  9. Close the ink cartridge access door.
Review the list of frequently asked questions about replacing the ink cartridges.
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
