Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
  • Oplysning
    Lær hvordan du kan opgradere til Windows 11
    Windows 11-opgraderingsvejledning.
Funktioner
Indlæser...
HP LaserJet Pro M118dw Printers - Replacing the Toner Cartridge
This document is for HP LaserJet Pro M118dw printers.
Replace the toner cartridge when the toner is low and print quality becomes unacceptable. A Toner Low or Toner Very Low message might display, and the Attention light on the control panel might blink.
Replace the toner cartridge.
  1. Open the cartridge door.
     Opening the cartridge door
  2. Grasp the toner cartridge handle, and then pull to remove the toner cartridge.
    Removing the toner cartridge
  3. Recycle the old toner cartridge.
  4. Remove the new toner cartridge from the package.
  5. Align the new toner cartridge with the tracks inside the printer, and then push the toner cartridge until it firmly seats.
     Inserting the toner cartridge
  6. Close the cartridge door.
    The new toner cartridge is installed, and the printer is ready to print.
    Closing the cartridge door
Review the list of frequently asked questions about replacing toner cartridges.
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
