Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
HP Tango Printers - First Time Printer Setup
This document is for HP Tango and Tango X printers.
Unbox the printer, connect it to a power source, load paper, install ink cartridges, and then connect it to your wireless network.
Step 1: View an overview video
Step 2: Unbox the printer
Remove the printer from the box, and then set up the output tray or wrap.
  1. Remove the printer and power cord from the box.
  2. Remove and recycle all packing material.
  3. Set the printer on the output tray or wrap, aligning the four corners with the indentations.
    Aligning the printer on the tray or wrap
Step 3: Connect the printer to a power source
Connect the power cord to the rear of the printer, plug the other end of the power cord into an electrical outlet, and then turn on the printer.
Step 4: Load paper and install ink cartridges
Load plain U.S. letter of A4 paper in the input tray, and then install the ink cartridges that came with your printer.
  1. Slide the paper-width guides to the edges of the input tray.
    Sliding the paper-width guides to the edges of the input tray
  2. Insert a stack of plain white paper into the input tray.
    Loading paper
  3. Slide the paper-width guides in until they touch the edges of the paper.
    Sliding the paper-width guides in
  4. Gently press down on the ink door button to release the ink cartridge access door, and then lift the door until it stays in place.
    Opening the ink cartridge access door
  5. Wait until the carriage is idle and silent before you continue.
  6. Remove an ink cartridge from its package. Be careful to touch only the black plastic on the ink cartridge.
    Holding the ink cartridge by the sides
  7. Remove the plastic tape from the ink cartridge, and then discard or recycle the package and tape.
      advarsel:
    Do not touch the copper-colored contacts or the ink nozzles. Handling these parts can result in clogs, ink failure, and bad electrical connections.
    Removing the plastic tape
  8. With the nozzles toward the printer, insert the ink cartridge into its slot, and then squeeze the ink cartridge until it snaps into place.
    bemærk:
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Installing ink cartridges
  9. Repeat these steps for the other ink cartridge.
  10. Lower the ink cartridge access door, and then press gently to lock it into place.
    After you install the ink cartridges, the printer prints an alignment page.
  11. Wait for the alignment page to fully eject from the printer.
Step 5: Connect the printer to a network
Use the HP Smart app to connect the printer to a wireless network. HP Smart is a free app that helps you quickly and easily connect your printer to the network and manage printer settings. It is available for Android, Apple iOS, Windows 10, and macOS. If you are using a computer with Windows 8.1 (and earlier), use the WPS method to connect the printer to your network.
bemærk:
You can print a Wireless Quick Start Guide to help you set up your printer. Touch and hold the Information button on the control panel for at least 3 seconds. When the other control panel buttons light up, touch the Information button again to print a Wireless Quick Start Guide, and then follow the steps on the printed page.
Step 6: Enroll in HP Instant Ink (optional)
Your printer is eligible for HP Instant Ink, which can reduce your printing costs and save you time. After you enroll, your printer automatically monitors the printer ink levels, and then HP Instant Ink mails replacement ink cartridges when levels are low.
To enroll in HP Instant Ink or to learn more, go to Enrolling in HP Instant Ink.
For more information, go to hpsmart.com/tango (in English).
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
