32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 8 GB (unbuffered) on 64-bit computers
bemærk:
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Video
Integrated graphics
Integrated Intel UHD Graphics
bemærk:
Integrated video is not available if a graphics card is installed.
Audio
Integrated audio
Audio Codec: Realtek ALC3601
Audio jack presence detection
bemærk:
Integrated audio is not available if a sound card is installed.
Network
LAN: 1000BASE-T
Technology: Realtek RTL8111HSH
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
Expansion Slots
One M.2 socket 1, 2230 type for WLAN
One M.2 socket 3, 2280 type for SSD
I/O Ports and Jumpers
Back I/O ports
bemærk:
The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Figur : Menlo back I/O panel
Audio: Line in
Audio: Line out
Audio: Microphone
HDMI out
VGA out
Serial port
RJ45 Ethernet
USB 2.0: 2
USB 3.1: 4
Jumpers
Figur : Clear CMOS and clear password jumpers in the default positions
