Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
HP Color LaserJet Pro M180 Printers - Replacing Toner Cartridges
This document is for HP Color LaserJet Pro M180n, M180nw, and M181fw printers.
To replace the toner cartridge, open the toner cartridge door, remove the old toner cartridge, and then install the new toner cartridge.
bemærk:
The imaging drum is integrated into the toner cartridge. To replace the imaging drum, you must replace the toner cartridge.
Replace the toner cartridge
If a toner cartridge is empty, replace it with a new, genuine HP toner cartridge.
  1. Open the toner cartridge door.
    Figur : Opening the front door
    Opening front door
  2. Grasp the blue handle on the toner cartridge drawer, and then pull out the drawer.
    Figur : Pulling out the toner cartridge drawer
    Pulling out cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull the toner cartridge straight up to remove it.
    Figur : Removing the toner cartridge
  4. Remove the new toner cartridge package from the box, and then pull the release tab on the packaging.
    Figur : Pulling the release tab on the packaging
  5. Remove the toner cartridge.
      advarsel:
    Do not touch the imaging drum on the bottom of the toner cartridge. Fingerprints on the imaging drum can cause print quality problems.
    Figur : Do not touch the imaging drum
    Figur : Removing the toner cartridge from the packaging
  6. Grasp both ends of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    Figur : Gently rocking the toner cartridge back and forth
  7. Insert the new toner cartridge into the drawer. Make sure the color chip on the toner cartridge matches the color chip on the drawer.
    Figur : Inserting the toner cartridge into the printer
  8. Push the toner cartridge drawer into the printer.
    Figur : Pushing in the toner cartridge drawer
    Pushing in toner cartridge drawer
  9. Close the toner cartridge door.
    Figur : Closing the toner cartridge door
Review the list of frequently asked questions about replacing the toner cartridges.
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
