This document is for HP DeskJet 2130, 2131, 2132, 2134, 2136, 2320, DeskJet Ink Advantage 2134, 2135, 2136, 2138, 2336, 2374, 2375, and 2376 All-in-One printers.
Replace cartridges that are low or out of ink with new, genuine HP cartridges.
advarsel:Do not touch the copper-colored contacts or the ink nozzles.Do not replace the protective tape on the contacts. Handling these parts can result in clogs, ink failure, and bad electricalconnections.
bemærk:The printer only prints an alignment page automatically when new ink cartridges are installed.
