Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
  • Oplysning
    Lær hvordan du kan opgradere til Windows 11
    Windows 11-opgraderingsvejledning.
Funktioner
Indlæser...
HP DeskJet Printers - Setting Up the Printer Hardware
This document is for the HP Deskjet 2510, 2511, 2512, 2514, Deskjet Ink Advantage 2515, 2516, 2520hc, and DeskJet Ultra Ink Advantage 2529 All-in-One printers.
This document explains how to set up the physical parts of the printer. In addition to the steps in this document, the software CD includes basic video demonstrations to set the language and set up your printer hardware before installing the software. You can follow the hardware setup steps on the software installation CD or refer to this document for detailed instructions to set up the hardware.
This document includes the following steps to set up the printer:
  • Unpack the printer
  • Connect the power cord and turn on the power
  • Load paper
  • Install the ink cartridges
  • Align the ink cartridges
bemærk:
The images in some of these steps might not look exactly like your printer, but the steps are the same.
Funktioner
Indlæser...
Funktioner
Indlæser...
Funktioner
Indlæser...
Land/område: Flag Danmark
Funktioner
Indlæser...
