- ${title}
Indlæser...
- ${title}
Indlæser...
- ${title}
Indlæser...
- ${title}
Indlæser...
HP Deskjet F2200 All-in-One Printer Series - Setting up the All-in-One (Hardware)
Unpack the product
Connect the power cord and adapter
Turn on power
Load plain paper
Install the cartridges
Align the cartridges
Follow these steps in order.
Step one: Unpack the product
Lower the paper tray.Figur : Lower the paper tray
Lower the cartridge door and remove all packing material.Figur : Remove the packaging material
bemærk:USB cables are not included with new printers. To order optional accessories such as USB cables, click the 'How to Buy' link on this page to purchase the accessory. If the accessory is not available from HP, there are many resellers that carry HP-compatible accessories.
Step two: Connect the power cord and adapter
Connect the power adapter to the back of the product.
Connect the power cord to the power adapter.
bemærk:
The power cord is either in a separate packet with the product or it inside the paper tray along with the cartridges. -
Connect the other end of the power cord to an electrical outlet.Figur : Plug in the power cord
Step three: Turn on power
Press the power button (
) to turn on the
product.
Figur : Power button on the product
Step four: Load plain paper
Flip the paper tray extender.Figur : Pull out the tray extender
Make sure the paper-width guide is in its outermost position.
Insert the stack of paper into the input tray with the short-edge forward and the print-side down. Slide the stack of paper forward until it stops.Figur : Load paper
advarsel:
Make sure that the HP product is idle and silent when loading paper into the main input tray. If the HP product is servicing the cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. If the paper is too far forward, the HP product might eject blank pages. -
Slide the paper-width guide inward until it stops at the edge of the paper.
bemærk:
Do not overload the input tray. Make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Step five: Install the cartridges
Make sure that the product is turned on.
advarsel:
The product must be on to release the cartridges. Trying to remove the cartridges while the product is off might damage the product. -
Open the cartridge door.Figur : Open the cartridge door
bemærk:
Make sure that the carriage moves to the center of the product. If the carriage does not move to the center, turn the product off and then turn it back on again. -
Remove the new cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape by using the pink pull tab.Figur : Remove the tape from a cartridge
advarsel:
Do not touch the copper-colored contacts or ink nozzles. Contact with these parts can result in clogs, ink failure, and bad electrical connections.Figur : Copper-colored contacts -
Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot.
If installing the tri-color cartridge, slide it into the left slot.
If installing a black, photo, or gray photo cartridge, slide it into the right slot.
Figur : Insert the cartridges -
Push the cartridge in firmly until it snaps into placeFigur : Push the cartridge in firmly
Close the cartridge door.Figur : Close the cartridge door
The product prints an alignment page because it recognizes that a new cartridge has been installed. Save the alignment page for the next step.
Step six: Align the cartridges
After the product prints an alignment page, follow these steps to complete the alignment process.
Make sure that there is letter or A4 unused plain white paper loaded in the input tray.
Life the product lid.
Place the cartridge alignment sheet print-side down on the left, front corner of the glass with the top of the page to the left.Figur : Load the alignment sheet
Press the Scan button (
The product aligns the cartridges. Recycle or discard the cartridge alignment sheet.
Yderligere muligheder for support
- ${title}
Indlæser...
- ${title}
Indlæser...
- ${title}
Indlæser...
Land/område:
Danmark
- ${title}
Indlæser...
hp-hero-support-search
- ${title}
Indlæser...
