KOMUNIKACE PODPORY- CUSTOMER ADVISORY
ID dokumentu: c06979955
Verze: 1
HP Commercial Notebook and Desktop PCs - Sure Start Recovery Error Appears
Notice: The information in this document, including products and software versions, is current as of the release date.The document is subject to change without notice.
Datum vydání : 08-Dec-2020
Naposledy aktualizováno : 08-Dec-2020
POPIS
The following message appears indicating a problem with HP Sure Start Recovery:
HP Sure Start detected an unauthorized change to Critical BIOS settings. These settings were restored automatically and there is no further action required. The repeated occurrence of this problem indicates a security problem that should not be ignored. Please see the HP Sure Start whitepaper for more information.
This affects all commercial computers with a common core BIOS products with HP Sure Start Recovery that supports Critical BIOS settings and the Battery Health Manager feature (if an older BIOS is installed on the computer).
Figure 1. HP Sure Start recovery error.
HP Sure Start Recovery message
ROZSAH
The information in this document applies to the following:
Notebook Computers:
  • HP Elite Dragonfly Notebook PC series
  • HP Elite x2 1013 G3 series
  • HP Elite x2 G4 series
  • HP EliteBook 1050 G1 Notebook PC series
  • HP EliteBook 735 G5 Notebook PC series
  • HP EliteBook 735 G6 Notebook PC series
  • HP EliteBook 745 G5 Notebook PC series
  • HP EliteBook 745 G6 Notebook PC series
  • HP EliteBook 830 G5 Notebook PC series
  • HP EliteBook 830 G6 Notebook PC series
  • HP EliteBook 830 G7 Notebook PC series
  • HP EliteBook 840 G5 Healthcare Edition Notebook PC series
  • HP EliteBook 840 G5 Notebook PC series
  • HP EliteBook 840 G6 Healthcare Edition Notebook PC series
  • HP EliteBook 840 G6 Notebook PC series
  • HP EliteBook 840 G7 Notebook PC series
  • HP EliteBook 840r G4 Notebook PC series
  • HP EliteBook 846 G5 Notebook PC series
  • HP EliteBook 846r G4 Notebook PC series
  • HP EliteBook 850 G5 Notebook PC series
  • HP EliteBook 850 G6 Notebook PC series
  • HP EliteBook 850 G7 Notebook PC series
  • HP EliteBook x360 1030 G3 Notebook PC series
  • HP EliteBook x360 1030 G4 Notebook PC series
  • HP EliteBook x360 1040 G5 Notebook PC series
  • HP EliteBook x360 1040 G6 Notebook PC series
  • HP EliteBook x360 1040 G7 Notebook PC series
  • HP EliteBook x360 830 G5 Notebook PC series
  • HP EliteBook x360 830 G6 Notebook PC series
  • HP ProBook 430 G6 Notebook PC series
  • HP ProBook 430 G7 Notebook PC series
  • HP ProBook 440 G5 Notebook PC series
  • HP ProBook 440 G6 Notebook PC series
  • HP ProBook 440 G7 Notebook PC series
  • HP ProBook 445 G6 Notebook PC series
  • HP ProBook 445R G6 Notebook PC series
  • HP ProBook 450 G5 Notebook PC series
  • HP ProBook 450 G6 Notebook PC series
  • HP ProBook 450 G7 Notebook PC series
  • HP ProBook 455 G5 Notebook PC series
  • HP ProBook 455 G6 Notebook PC series
  • HP ProBook 455R G6 Notebook PC series
  • HP ProBook 470 G5 Notebook PC series
  • HP ProBook 640 G4 Notebook PC series
  • HP ProBook 640 G5 Notebook PC series
  • HP ProBook 640 G7 Notebook PC series
  • HP ProBook 645 G4 Notebook PC series
  • HP ProBook 650 G4 Hex Core Notebook PC series
  • HP ProBook 650 G4 Notebook PC series
  • HP ProBook 650 G5 Notebook PC series
  • HP ProBook 650 G7 Notebook PC series
  • HP ProBook x360 11 G4 EE Notebook PC series
  • HP ProBook x360 440 G1 Notebook PC series
  • HP ZBook 14u G5 Mobile Workstation series
  • HP ZBook 14u G6 Mobile Workstation series
  • HP ZBook 15 G5 Mobile Workstation series
  • HP ZBook 15 G6 Mobile Workstation series
  • HP ZBook 15u G5 Mobile Workstation series
  • HP ZBook 15u G6 Mobile Workstation series
  • HP ZBook 17 G5 Mobile Workstation series
  • HP ZBook 17 G6 Mobile Workstation series
  • HP ZBook Studio G5 Mobile Workstation series
  • HP ZHAN 66 Pro 13 G2 Notebook PC series
  • HP ZHAN 66 Pro 14 G2 Notebook PC series
  • HP ZHAN 66 Pro 14 G3 Notebook PC series
  • HP ZHAN 66 Pro 15 G2 Notebook PC series
  • HP ZHAN 66 Pro G1 Notebook PC series
  • HP ZHAN X 13 G2 Notebook PC series
Desktop Computers:
  • HP Engage Go Mobile Systems
  • HP mt21 Mobile Thin Client series
  • HP mt31 Mobile Thin Client series
  • HP mt44 Mobile Thin Client series
  • HP mt45 Mobile Thin Client series
  • HP ZHAN 66 Pro G3 22 All-in-One PC series
  • HP ZHAN 66 Pro G3 24 All-in-One PC series
Operating Systems:
  • Microsoft Windows 10 19H2 (Version 1909)
  • Microsoft Windows 10 RS5 (Version 1809)
  • Microsoft Windows 10 RS4 (Version 1803)
  • Microsoft Windows 10 20H2
  • Microsoft Windows 10 20H1 (Version 2004)
  • Microsoft Windows 10 19H1 (Version 1903)
ROZLIŠENÍ
To work around this issue, perform the following steps to disable Sure Start BIOS Settings Protection in HP Computer Setup (F10) in the Security menu under BIOS Sure Start.
  1. Turn on or restart the computer.
  2. Press F10 to enter the BIOS Setup.
  3. Select Security.
  4. Locate BIOS Sure Start.
  5. Uncheck Sure Start BIOS Settings Protection.
  6. Click Save to save the changes and exit HP Computer Setup.
To resolve this issue, download and install the October 2020 BIOS release (or later) which contains the fix for this issue.
Poznámka:
First, disable (uncheck) the Sure Start BIOS Settings Protection feature (as seen in the above steps) to update the BIOS successfully. Also, ensure Bitlocker is suspended before proceeding (if Bitlocker is enabled on the computer).
To download and install the October 2020 BIOS Update (or later), refer to the following link HP Customer Support - Products.
  1. Enter your HP computer product name and model number.
  2. Click Find.
  3. Select Software, Drivers and Firmware.
  4. Locate and expand BIOS.
  5. Download and install the appropriate BIOS update for your computer.
Below are the minimum BIOS versions that contains the fix for the following products:
Affected Platforms
Minimum BIOS Version
HP EliteBook x360 1030/1040 G7 Notebook PCs
HP EliteBook 850/840/830 G7 Notebook PCs
HP EliteBook x360 830 G7 Notebook PCs
HP ProBook 650/640 G7 Notebook PCs
HP ZBook 14u/15u G7 Mobile Workstations
01.03.01
HP EliteBook 850/840/830 G6 Notebook PCs
HP EliteBook 840 G6 Healthcare Edition Notebook PCs
HP EliteBook x360 830 G6 Notebook PCs
HP ProBook 650/640 G5 Notebook PCs
HP EliteBook x360 1040 G6/EliteBook x360 1030 G4 PCs
HP Elite Dragonfly Notebook PCs
HP Elite x2 G4
HP ProBook 450/440/430 G7 Notebook PCs
HP ZHAN 66 Pro 15/14 G3 Notebook PCs
HP ZHAN X 13 G2 Notebook PCs
HP Zbook 14u/15u G6 Mobile Workstations
01.07.02
HP Elitebook 745/735 G6 System BIOS
HP mt45 Mobile Thin Client Systems
HP ZBook 17/15 G6 Mobile Workstations
01.07.01
HP ProBook x360 11 G4 Education Edition PCs
01.08.00
HP Elite x2 1013 G3 Tablets
HP EliteBook 1050 G1 Notebook PCs
HP EliteBook 745/735 G5 Notebook PCs
HP EliteBook 840r/846r G4 Notebook PCs
HP EliteBook 850/846/840/836/830 Healthcare Edition Notebook PCs
HP EliteBook 840 G5 Healthcare Edition Notebook PCs
HP EliteBook x360 1030 G3 Notebook PCs
HP EliteBook x360 1040 G5 Notebook PCs
HP EliteBook x360 830 G5 Notebook PCs
HP mt21 Mobile Thin Client Systems
HP mt31 Mobile Thin Client Systems
HP mt44 Mobile Thin Client Systems
HP ProBook 430/440/450 G6 Notebook PCs
HP ProBook 445/455 G6 Notebook PCs
HP ProBook 445R/455R G6 Notebook PCs
HP ProBook 455 G5 Notebook PCs
HP ProBook 470/450/440/430 G5 Notebook PCs
HP ProBook 645 G4 Notebook PCs
HP ProBook 650/640 G4 Notebook PCs
HP ProBook x360 440 G1 Notebook PCs
HP ZBook 14u/15u G5 Mobile Workstations
HP ZBook 15/17 G5 Mobile Workstations
HP ZBook Studio G5 Mobile Workstations
HP Zhan 66 Pro 13/14/15 G2 Notebook PCs
HP ZHAN 66 Pro G1 Notebook PCs
01.14.01
Hardware platforms affected : HP Elite Dragonfly Notebook PC, HP Elite Dragonfly Notebook PC, HP Elite Dragonfly Notebook PC Configurable Material, HP Elite x2 1013 G3, HP Elite x2 G4, HP EliteBook 1050 G1 Notebook PC, HP EliteBook 735 G5 Notebook PC, HP EliteBook 735 G6 Notebook PC, HP EliteBook 735 G6 Notebook PC Configurable Material, HP EliteBook 745 G5 Notebook PC, HP EliteBook 745 G6 Notebook PC, HP EliteBook 745 G6 Notebook PC Configurable Material, HP EliteBook 830 G5 Notebook PC, HP EliteBook 830 G6 Notebook PC, HP EliteBook 830 G7 Notebook PC, HP EliteBook 830 G7 Notebook PC (Camellia13 1.0) Configurable Material, HP EliteBook 840 G5 Healthcare Edition Notebook PC, HP EliteBook 840 G5 Notebook PC, HP EliteBook 840 G6 Healthcare Edition Notebook PC, HP EliteBook 840 G6 Healthcare Edition Notebook PC Configurable Material, HP EliteBook 840 G6 Notebook PC, HP EliteBook 840 G6 Notebook PC (Crescent14 1.0) Configurable Material, HP EliteBook 840 G7 Notebook PC, HP EliteBook 840 G7 Notebook PC (Camellia14 1.0) Configurable Material, HP EliteBook 840r G4 Notebook PC, HP EliteBook 846 G5 Notebook PC, HP EliteBook 846r G4 Notebook PC, HP EliteBook 850 G5 Notebook PC, HP EliteBook 850 G6 Notebook PC, HP EliteBook 850 G6 Notebook PC (Crescent15 1.0) Configurable Material, HP EliteBook 850 G7 Notebook PC, HP EliteBook 850 G7 Notebook PC (Camellia15 1.0) Configurable Material, HP EliteBook x360 1030 G3 Notebook PC, HP EliteBook x360 1030 G3 Notebook PC Configurable Material, HP EliteBook x360 1030 G4 Notebook PC, HP EliteBook x360 1030 G4 Notebook PC Configurable Material, HP EliteBook x360 1040 G5 Notebook PC, HP EliteBook x360 1040 G6 Configurable Product, HP EliteBook x360 1040 G6 Notebook PC, HP EliteBook x360 1040 G7 Notebook PC, HP EliteBook x360 1040 G7 Notebook PC (Hickory14) Configurable Material, HP EliteBook x360 830 G5 Notebook PC, HP EliteBook x360 830 G5 Notebook PC (Oreti) Configurable Material, HP EliteBook x360 830 G6 Notebook PC, HP EliteBook x360 830 G6 Notebook PC (Okiwi) Configurable Material, HP Engage Go Mobile System, HP Engage Go Mobile System Configurable Material, HP ProBook 430 G6 Notebook PC, HP ProBook 430 G6 Notebook PC (Reef) Configurable Material, HP ProBook 430 G7 Notebook PC, HP ProBook 430 G7 Notebook PC (Rimu 1.0) Configurable Material, HP ProBook 440 G5 Notebook PC, HP ProBook 440 G5 Notebook PC Configurable Material, HP ProBook 440 G6 Notebook PC, HP ProBook 440 G6 Notebook PC (Ramia) Configurable Material, HP ProBook 440 G7 Notebook PC, HP ProBook 440 G7 Notebook PC (Redbay 1.0) Configurable Material, HP ProBook 445 G6 Notebook PC, HP ProBook 445 G6 Notebook PC Configurable Material, HP ProBook 445R G6 Notebook PC, HP ProBook 445R G6 Notebook PC Configurable Material, HP ProBook 450 G5 Notebook PC, HP ProBook 450 G6 Notebook Configurable Material, HP ProBook 450 G6 Notebook PC, HP ProBook 450 G7 Notebook PC, HP ProBook 450 G7 Notebook PC Configurable Product, HP ProBook 455 G5 Notebook PC, HP ProBook 455 G6 Notebook PC, HP ProBook 455 G6 Notebook PC (Pelican15) Configurable Material, HP ProBook 455 G6 Notebook PC (Pigeon15) Configurable Material, HP ProBook 455R G6 Notebook PC, HP ProBook 470 G5 Notebook PC, HP ProBook 640 G4 Notebook PC, HP ProBook 640 G4 Notebook PC Configurable Material, HP ProBook 640 G5 Notebook PC, HP ProBook 640 G5 Notebook PC Configurable Material, HP ProBook 640 G7 Notebook PC, HP ProBook 640 G7 Notebook PC (CocoaR) Configurable Material, HP ProBook 645 G4 Notebook PC, HP ProBook 650 G4 Hex Core Notebook PC, HP ProBook 650 G4 Notebook PC, HP ProBook 650 G4 Notebook PC (Chromia15) Configurable Material, HP ProBook 650 G5 Notebook PC, HP ProBook 650 G5 Notebook PC (Coconut) Configurable Material, HP ProBook 650 G7 Notebook PC, HP ProBook 650 G7 Notebook PC (CoconutR) Configurable Material, HP ProBook x360 11 G4 EE Notebook PC, HP ProBook x360 11 G4 EE Notebook PC Configurable Material, HP ProBook x360 440 G1 Notebook PC, HP ZBook 14u G5 Mobile Workstation, HP ZBook 14u G6 Mobile Workstation, HP ZBook 15 G5 Mobile Workstation, HP ZBook 15 G6 Mobile Workstation, HP ZBook 15 G6 Mobile Workstation Configurable Material, HP ZBook 15u G5 Mobile Workstation, HP ZBook 15u G6 Mobile Workstation, HP ZBook 17 G5 Mobile Workstation, HP ZBook 17 G5 Mobile Workstation Configurable Material, HP ZBook 17 G6 Mobile Workstation, HP ZBook 17 G6 Mobile Workstation Configurable Material, HP ZBook Studio G5 Mobile Workstation, HP ZHAN 66 Pro 13 G2 Notebook PC, HP ZHAN 66 Pro 13 G2 Notebook PC Configurable Material, HP ZHAN 66 Pro 14 G2 Notebook PC, HP ZHAN 66 Pro 14 G3 Notebook PC, HP ZHAN 66 Pro 14 G3 Notebook PC (Sourwood14) Configurable Material, HP ZHAN 66 Pro 15 G2 Notebook PC, HP ZHAN 66 Pro 15 G2 Notebook PC Configurable Material, HP ZHAN 66 Pro G1 Notebook PC, HP ZHAN 66 Pro G3 22 All-in-One PC, HP ZHAN 66 Pro G3 24 All-in-One PC, HP ZHAN X 13 G2 Notebook PC, HP mt21 Mobile Thin Client series, HP mt31 Mobile Thin Client, HP mt31 Mobile Thin Client Configurable Material, HP mt44 Mobile Thin Client, HP mt45 Mobile Thin Client, HP mt45 Mobile Thin Client Configurable Material
Operační systémy, kterých se to týká : Netýká se
Software, kterého se to týká : Netýká se
ID křížového odkazu pro komunikaci podpory : IA06979955
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
Další možnosti podpory
