This document is for HP Laser 103a, 107a, 107r, 107w, 108a, 108w, 1003a, 1003w, 1008a, and 1008w printers.
- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
HP Laser 100, 1000 Printers - Replacing the Toner Cartridge
Replace the toner cartridge if it is low or empty.
To replace the toner cartridge, open the top cover, remove the old toner cartridge, and then install a new one.
Open the top cover.
Grasp the handle on the toner cartridge, and then pull the toner cartridge out to remove it.
Remove the new toner cartridge from its package, and then discard or recycle the packing materials.
Grasp both sides of the toner cartridge, and then distribute the toner by gently rocking the toner cartridge back and forth.
Align the new toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
Close the top cover.
Review the list of frequently asked questions about replacing toner cartridges.
Další možnosti podpory
- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
Země/oblast:
Česká republika
- ${title}
Načítání...
hp-hero-support-search
- ${title}
Načítání...
