Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
  • Zpětná vazba
Akce
Načítání...
HP OfficeJet Pro 8210 Printers - First Time Printer Setup
This document is for the HP OfficeJet Pro 8210, 8216, and 8218 printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then download and install the printer software.
Poznámka:
If you are looking for the printer software, go to http://123.hp.com/OJP8210 to download the print driver.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer, and then remove the film from the printer control panel.
    Obrázek : Removing tape from the printer
    Image: Removing tape from the printer
  3. Turn the printer, and then remove all tape from rear access panel.
    Obrázek : Removing tape from the rear access panel
  4. Recycle the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into a wall outlet, turn on the printer, and then set your preferences.
Poznámka:
    Obrázek : Connecting the power cord
    Image: Connecting the power cord
  2. Turn on the printer.
    Obrázek : Turning on the printer
  3. On the printer control panel, press the down arrow to select your preferred language and country/region, and then press OK.
    Obrázek : Selecting language from the control panel
    Image: Selecting language from the control panel
  4. If prompted, select the date and time, and then press OK.
Step 3: Load paper into the input tray
Load plain U.S. letter or A4 paper in the input tray.
  1. Pull out the input tray.
    Obrázek : Pulling out the input tray
  2. Slide out the paper guides as far as possible.
    Obrázek : Sliding out the paper guides
  3. Load paper in portrait orientation with the print side facing down.
    Obrázek : Loading plain paper
    Load plain white paper
  4. Slide the paper guides until they touch the edge of the stack of paper.
    Do not push the guides in so tightly that they bind against the paper.
    Obrázek : Sliding in the paper guides
    Sliding the paper-width guides and paper-length guide
  5. Make sure the stack of paper does not exceed the paper fill guide.
    Obrázek : Do not exceed stack height
    Do not exceed stack height marking
  6. Insert the input tray into the printer.
Step 4: Install the SETUP ink cartridges
Install the HP SETUP ink cartridges that came in the box with your printer.
  Upozornění:
You must install the SETUP ink cartridges when first setting up the printer, or an ink cartridge error occurs.
  1. Open the ink cartridge access door.
    Obrázek : Opening the ink cartridge access door
  2. Wait until the carriage is idle and silent before you continue.
  3. Remove the ink cartridge from the package.
  4. Insert the ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
    Obrázek : Reinserting the ink cartridge
  5. Repeat these steps for the other ink cartridges.
  6. Close the ink cartridge access door.
    The printer starts an initialization process. It is normal for the printer to make noises during this process. After the process completes, the printer prints an alignment page.
Step 5: Install the printer software
You can download the latest version of the printing software from http://123.hp.com/OJP8210.
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
