This document explains how to set up your printer hardware HP Deskjet 1010 and HP HP Deskjet Ink Advantage 1010 printers.
Poznámka:Do not connect the USB cable until instructed to do so.
Upozornění:Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
