Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
  • Zpětná vazba
Akce
Načítání...
Setting Up the Printer Hardware for HP Deskjet 3050 (J610a) All-in-One Printer Series
Setting up the printer
Step one: Unpack the printer
  1. Remove the tape and cardboard from the outside of the printer.
    Obrázek : Remove the tape from the outside of the printer
    Graphic: Remove tape from the outside of the printer
  2. Open the front access door, open the cartridge access door, and then remove the tape and cardboard from inside the printer.
    Obrázek : Remove the tape and cardboard from inside the printer
    Graphic: Remove the tape and cardboard from inside the printer
  3. Close the cartridge access door.
    Obrázek : Close the cartridge access door
    Graphic: Close the cartridge access door
Step three: Connect the power cord and adapter
  1. Connect the power cord to the back of the printer.
    Obrázek : Connect the power cord into the back of the printer
    Graphic: Connect the power cord to the rear of the printer
  2. Connect the power cord to the power supply, and then into a power outlet in the wall.
    Obrázek : Connect the power cord to the power supply, and then into a power outlet in the wall
    Graphic: Connect the power cord to the power supply, and then into a power outlet in the wall
Step four: Turn on the power
Press the Power button to turn on the printer.
Obrázek : Turn on the printer
Graphic: Turn on the printer
Step five: Select the language and region
After turning the printer on, a list of possible language settings displays on the printer control panel. Use the following steps to set the default language and country/region for your printer.
  1. On the printer control panel, press the button () next to the Down Arrow () to scroll through the languages, if necessary.
  2. Press the button () next to OK to confirm your selection.
  3. Press the button () next to the Down Arrow () to scroll through the regions, if necessary.
  4. Press the button () next to OK to confirm your selection.
    Obrázek : Select your language and region from the printer control panel
    Graphic: Select language and region
Step six: Load plain paper
  1. Raise the input tray.
    Obrázek : Raise the input tray
    Graphic: Raise the input tray
  2. Pull out the tray extender.
    Obrázek : Pull out the tray extender
    Grahpic: Pull out the tray extender
  3. Slide the paper width guide to its outermost position, and then load plain, white paper into the input tray.
    Obrázek : Slide the paper width guide outward and load paper
    Grahpic: Slide paper width guide outward and load paper
  4. When prompted, press the button () next to OK on the printer control panel to confirm that paper is loaded in the printer.
    Obrázek : Press the button next to OK on the printer control panel
    Graphic: Press the button next to OK on the printer control panel
Step seven: Install the cartridges
  1. Open the cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
    Obrázek : Open the cartridge access door
    Graphic: Open the cartridge access door
  2. Remove the new cartridge from its packaging, and then carefully pull the pink pull tab to remove the plastic tape.
      Upozornění:
    Do not touch the copper-colored contacts or ink nozzles. Also, donot re-tape the cartridges. Doing so can result in clogs, ink failure, and badelectrical connections.
    Obrázek : Remove the plastic tape
    Graphic: Remove tape from the cartridge
  3. Hold the cartridge by its sides with the nozzles toward the printer, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
    • The tri-color cartridge () goes in the slot on the left
    • The black cartridge () goes in the slot on the right
    Obrázek : Insert the cartridge into its slot
    Graphic: Inserting the cartridge
  4. Push the cartridge forward into its slot until it snaps into place.
    Obrázek : Snap the cartridge into place
    Graphic: Snap the cartridge into place
  5. Repeat these steps to insert the other cartridge.
  6. Close the cartridge access door.
    Graphic: Close the cartridge door
  7. Press the button () next to OK on the printer control panel.
  8. Wait about 30 seconds for the alignment page to automatically print.
    Obrázek : The alignment page prints automatically after 30 seconds
    Graphic: The alignment page  prints automatically after 30 seconds
Step eight: Align the cartridges
  1. Lift the scanner lid.
  2. Place the alignment page with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.
    Obrázek : Place the alignment page on the scanner glass
    Graphic: Place the alignment page on the scanner glass
  3. Close the scanner lid.
    Obrázek : Close the scanner lid
    Graphic: Close the scanner lid
  4. Press the button () next to OK on the printer control panel.
    The printer scans the alignment page and completes the alignment process.
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
