Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
HP Notebook PCs - Transferring Files Using Windows Easy Transfer in Vista
Understanding Windows Easy Transfer
Windows Easy Transfer is a useful tool for transferring the files and settings from an old computer that is running Windows 2000, Windows XP, or even Windows Vista to a new computer that is running Windows Vista. Windows Easy Transfer is also useful for transferring the files and settings from one account to a new account on the same computer.
Windows Easy Transfer automatically transfers the following:
  • User accounts
  • Files and folders
  • E-mail messages, settings, and contacts
  • Photos, music, and videos
  • Windows settings
  • Program data files and settings
  • Internet settings
Transferring data between two computers
There are several ways to use Windows Easy Transfer; choose the way you prefer to connect your two computers, choose the data you want to transfer, and then let Windows Easy Transfer do the work for you.
Poznámka:
If your old computer is not running Windows Vista, the Windows Easy Transfer instructions guide you through copying Windows Easy Transfer to the media that you are using to complete the transfer.
Using an Easy Transfer Cable
Microsoft recommends using an Easy Transfer Cable for transferring files and settings between computers. However, you may choose to use any of the alternate methods if you did not purchase an Easy Transfer Cable.
To use this method, you will need the Easy Transfer Cable and a USB port on both computers. The Easy Transfer Cable is a USB cable that connects to two computers at the same time. It works with Windows Easy Transfer to move information between the computers. Always start Windows Easy Transfer on the new computer first and follow the on-screen instructions. The instructions indicate if it is necessary to download the Windows Easy Transfer software on the old computer, when to plug in the cable, and guides you through the transfer process.
Poznámka:
If you did not purchase an Easy Transfer Cable with your computer, you can order one online or purchase one at an electronics retailer.
Using a home or small business network
To use this method, you need a network (home or business) with both computers connected to the same network. On your new computer, start Windows Easy Transfer and then follow the on-screen instructions.
  Upozornění:
To prevent lost or damaged data, do not start Windows Easy Transfer on your old computer first.
To transfer files directly over a network without copying to and from a network location, a Windows Easy Transfer key is necessary. This is a password that the new computer generates as you step through the Windows Easy Transfer program. It is necessary to type this key into your old computer before you can select files and settings for transfer. The key helps protect files and settings when you transfer them over the network.
Using a USB flash drive or external hard drive
If you are using a USB flash drive or an external hard drive, Windows Easy Transfer estimates how much disk space is needed to transfer your selections. If you are using a USB flash drive, try to use one with enough storage space for the entire transfer. If you do not have enough storage space on the USB flash drive for the entire transfer, copy as many files as possible and then repeat the process until you have transferred all of your files and settings.
Using CDs or DVDs
If you are using CDs or DVDs, Windows Easy Transfer estimates how much disk space and now many discs are necessary for transferring your selections. Both computers must be able to read from and write to CDs, DVDs, and dual-layer DVDs.
Starting Windows Easy Transfer
After choosing a method for transferring your data between two computers, start Windows Easy Transfer by using the one of following methods, and then follow the on-screen instructions.
  • Click Start, type easy into the Search field, and then select Windows Easy Transfer from the list.
  • Click Start > All Programs > Accessories > System Tools > Windows Easy Transfer.
  • Click Start, Help and Support, type easy into the Search field and then press enter. A list of results displays. Select an Easy Transfer topic from the list.
Transferring data from one account to another account on the same computer
Transferring data from one account to another account on the same computer involves creating a migration file, creating a new user account, and then transferring the data from the migration file to the new account.
Creating a migration file
A migration file allows you to easily transfer data to a new account on the same computer.
To create a migration file, follow the steps below.
  1. Turn on the computer.
  2. Log into the account from which you want to transfer files.
  3. Click Start, type easy into the search field, and then select Windows Easy Transfer from the list. Grant permission to continue, if prompted. Windows Easy Transfer opens.
  4. Click Next.
  5. Click Start a new transfer.
  6. Click My old computer under Which computer are you using now?.
  7. Click Transfer directly, using a network connection under Choose how to transfer files and settings to you new computer.
  8. Click Copy to and from a network location under Choose how to transfer files and settings over a network.
  9. A default location, C:\from_old_computer\SaveData.MIG, populates into the Network location: field. Accept the default location by clicking Next.
  10. Click My user account, files, and settings only under What do you want to transfer to your new computer? Review the selected files and settings, and then click Transfer.
  11. After the transfer completes, click Close to close Windows Easy Transfer.
You have now created a migration file, which will be used to transfer your files and settings to a new account on the computer.
Creating a new user account
Prior to using the migration file that you just created a new account on your computer, you must first create the new account.
To create a new user account on your computer, follow the steps below.
  1. Click Start, Control Panel, and then User Accounts and Family Safety.
  2. Click Add or remove user accounts under User Accounts. Grant permission to continue, if prompted.
  3. Click Create a new account, enter an account name, select Administrator, and then click Create Account.
You have now created a new user account
Transferring data from the migration file to the new account
After creating the migration file and new account, use the migration file to move your files and settings to the new account.
To transfer data from the migration file to the new account, follow the steps below.
  1. Log off of the old user account and then log into the new user account.
  2. Click Start, Computer, C:\, and then open the from_old_computer folder.
  3. Open the SaveData file. Grant permission to continue, if prompted.
  4. Select the name of the new user account that you just created from the drop-down list and then click Next.
  5. Review the selected files and settings and then click Transfer to import the files and settings into the new user account. Wait while the transfer completes.
  6. Click Close after the transfer completes.
  7. Restart your computer for the changes to take effect.
  8. Log back into the new user account, type the password for the old account into the password field on the Protected Content Migration window, and then click Confirm my account information and update content protection.
    Poznámka:
    You will still need to create a new password for the new user account.
You have now transferred the files and settings from one account to a new account on the same computer.
Verify that all of the data that you transferred to the new account is correct. If it is correct, you can delete the old user account.
See also
On the Microsoft web site, search for articles on Easy Transfer.
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
Akce
Načítání...
