- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
HP Deskjet F300 All-in-One Printer Series- Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Connect the power cord and adapter
Load plain paper
Turn on power
Install the cartridges
Follow these steps in order.
Lower the cartridge door.Obrázek : Open the cartridge door
Remove all tape and packing material from the product.Obrázek : Remove all packing materials
Step three: Connect the power cord and adapter
Plug the printer end of the power adapter into the back of the product.
Plug the adapter end of the power cord into the power adapter.
Plug the remaining end of the power cord into a grounded wall outlet or surge protector.
Obrázek : Connect the power cord and adapter
Step four: Load plain paper
Slide the paper-width guide to its widest position and flip the paper tray extender towards you.Obrázek : Slide the paper guide
Insert plain white letter or A4 paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops.Obrázek : Insert paper
Upozornění:
Make sure that the product is idle and silent when loading paper into the input tray. If the product is servicing the cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages. -
Slide the paper-width guide inward until it stops at the edge of the paper.Obrázek : Adjust the paper guides
Poznámka:
Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Step five: Turn on power
Press the button next to the On light (
) on the product control panel.
Obrázek : On button
Step six: Install the cartridges
Open the cartridge door. Make sure that the carriage moves to the center of the product.Obrázek : Open the cartridge door
Remove each new cartridge from its packaging. Touching only the black plastic, gently remove the plastic tape by using the pink pull tab.
Copper-colored contacts
Plastic tape with pink pull tab (must be removed before installing)
Ink nozzles under tape
Obrázek : Remove the tapeUpozornění:
Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. -
Slide each new cartridge forward into the empty slot. Then gently push on the upper part of the cartridge until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black or photo cartridge, slide it into the right slot.
Obrázek : Insert the cartridge -
Close the cartridge door.Obrázek : Close the cartridge door
Wait a few minutes while the alignment page prints automatically.
Poznámka:
If you remove and reinstall the same cartridge, the product does not print an alignment page. The product remembers the alignment values for that cartridge, so you do not need to realign the cartridges.If the cartridge alignment sheet prints, follow these steps:-
Load the alignment sheet on the left front corner of the scanner glass with the top of the page to the left.Obrázek : Load the alignment sheet on the scanner glass
Make sure that there is plain paper loaded in the input tray, and then press the Scan (
) button.
The product aligns the cartridges. Recycle or discard the cartridge alignment sheet.Poznámka:
If you do not scan the alignment page within 5 minutes, the product will print out an alignment page after the next print job. If the alignment is ignored, no further alignment pages will be printed unless manually initiated.
Další možnosti podpory
- ${title}
Načítání...
- ${title}
Načítání...
- ${title}
Načítání...
Země/oblast:
Česká republika
- ${title}
Načítání...
hp-hero-support-search
- ${title}
Načítání...
