This device complies with Part 15 of the Federal Communication Commission rules. Operation is subject to the following two conditions: 1) this device may not cause harmful interference, and 2) this device must accept any interference received, including interference that may cause undesired operation.
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a commercial environment. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications.
在住宅区使用本设备可能会产生有害干扰,在这种情况下,用户必须排除干扰,费用自担。如果本设备确实对无线电或电视接收造成干扰(可以通过开关设备来确定),建议用户采取以下一种或多种措施排除干扰:
FCC Caution: The FCC requires the user to be notified that any changes or modifications made to this device that are not expressly approved by Hewlett-Packard Company may void the user's authority to operate the equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
警告 - 暴露在射频辐射下 尽管本设备的辐射输出功率低于 FCC 射频暴露限值,但使用本设备的方式应使人员在设备正常运行时接触天线的可能性降至最低。为了避免超出 FCC 对于射频暴露的限制,在正常运行时,人体与天线之间的距离不应小于 20 厘米(8 英寸)。
