    Think you need a hardware repair or want to check repair status? Try our HP repair center
    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
    Fix HP Printer issue on macOS
HP Laptop - 15s-eq1023nh Product Specifications
1U9S9EA
AMD Ryzen™ 3 3250U (2.6 GHz base clock, up to 3.5 GHz max boost clock, 1 MB L2 cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
128 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours
Video Playback Battery life
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
ExpressVPN (30 day free trial)
Country/Region: Flag Canada
