    Think you need a hardware repair or want to check repair status? Try our HP repair center
    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
    Fix HP Printer issue on macOS
OMEN by HP 15-dh0037no Product Specifications
8PK70EA
Intel® Core™ i9-9880H (2.3 GHz base frequency, up to 4.8 GHz base with Intel® Turbo Boost Technology, 16 MB cache, 8 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
36 x 26 x 2.04 cm
2.32 kg
200 W Smart AC power adapter
6-cell, 69 Wh Li-ion polymer
Battery life mixed usage
Up to 4 hours and 45 minutes
Video Playback Battery life
Up to 3 hours and 15 minutes
Audio by B&O; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Country/Region: Flag Canada
