HP Desktop PCs - Motherboard Specifications, Bali-U
Figure : Bali-U motherboard
Motherboard description
HP name: Bali-U
SSID: 8245
Form Factor
Customized: 15.0x14.0 cm (5.9x5.5 in)
The chipset on this motherboard is combined with the processor into a single integrated circuit called System on a Chip (SoC). This technology combines the processor and chipset functionality into a single physical package.
Processor upgrade information
Supports the AMD E2-7110, AMD A4-7210, AMD A6-7310, AMD A8-7410 (Carrizo-L) Quad Core processors only. The processor is not upgradeable.
Memory upgrade information
Single channel memory architecture
One DDR3L SODIMM (204-pin) socket
Supports up to PC3L-12800 (DDR3L-1600)
Supports 2 GB, 4 GB, and 8 GB SODIMMs
Supports up to 4 GB on 32-bit systems
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 8 GB on 64-bit systems
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
