HP EliteBook 2560p Notebook PC - Removing and Replacing the Display Bezel
This document is provided to assist in removing and replacing the display bezel for the HP EliteBook 2560p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the display bezel that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
LCD bezel with webcam
651366-001 (Modified)
Yes
LCD bezel without webcam
651365-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the display bezel, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Display bezel from the menu on the upper left hand side of the screen.
Click here to view the display bezel removal video (right-click on the link to open in a new window/tab).
Display bezel removal
Observe all precautions when removing and replacing components.
The display bezel can be removed without first detaching the display assembly from the base enclosure.
  2. Open the notebook fully.
  3. Carefully pry up the inside edges of the display bezel from sides, top, and bottom, to disengage the display bezel from the display enclosure.
  4. Lift and remove the display bezel.
Display bezel replacement
  1. Place the display bezel in place on the display enclosure.
  2. Press down around the bottom, sides, and top of the display bezel to snap it into place on the display enclosure.
Country: Flag Canada
