HP LaserJet Managed Flow MFP E82540-E82560 series and HP LaserJet Managed MFP E82540-E82560 series - Removal and replacement: Toner collection unit (TCU)
This document provides the procedures to remove and replace the toner collection unit (TCU).
Mean time to repair: 1 minute
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Press the power button on the front of the printer, and then turn off the power switch next to the power cable.
  • A shutting-down message appears on the control-panel display.
      warning:
    To avoid damage to the printer, turn the power off and wait until the printer shuts down before removing the power cable.
  • Disconnect the printer power cable after the printer has completely shut down (the control-panel display is blank).
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
TCU part number
SAM-MLT-W706
HP Managed LJ Toner Collection Unit
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
  • Connect the printer power cable.
  • Turn on the power switch next to the power cable, and then press the power button on the front of the printer.
  • Verify that the service performed was successful.
  • Verify that the most recent firmware is installed on the printer.
  • Verify that all parts are correctly reinstalled and are properly working.
  • Verify that the printer is in better condition than when you arrived, cosmetically and electrically.
Post service test
Print any pages necessary to verify that the repair resolved the issue and did not create any new issues.
  1. Remove the TCU.
    1. Open the front cover.
    2. Push both hooks to release the toner collection unit (TCU).
      Figure : Remove the TCU
  2. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    3. To install an assembly, reverse the removal steps.
