681Y5PA
HP Laptop 14s-dq3037TU
Intel® Celeron® N4500 (up to 2.8 GHz burst frequency, 4 MB L3 cache, 2 cores)
Intel® Integrated SoC
8 GB DDR4-2933 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
35.6 cm (14") diagonal, HD (1366 x 768), micro-edge, BrightView, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
32.4 x 22.5 x 1.79 cm
Starting at 1.47 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop 14s-dq3037TU Product Specifications
Windows 11 Home
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
