HP Chromebook 14a-na0062tg Product Specifications
60L06UA
Intel® Pentium® Silver N5030 (1.1 GHz base frequency, up to 3.1 GHz burst frequency, 4 MB L2 cache, 4 cores)
Intel® Integrated SoC
4 GB LPDDR4-2400 MHz RAM (onboard)
Video graphics
  • Intel® UHD Graphics 605
  • Integrated
128 GB eMMC
Optical drive
Optical drive not included
14" diagonal, HD (1366 x 768), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.57 x 21.85 x 1.79 cm
1.46 kg
45 W USB Type-C™ power adapter
2-cell, 47 Wh Li-ion polymer
Battery life mixed usage
Up to 14 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
