HP Laptop 17-cn0082nm Product Specifications
526C3EA
Intel® Pentium® Silver N5030 (1.1 GHz base frequency, up to 3.1 GHz burst frequency, 4 MB L2 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics 605
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal, HD+ (1600 x 900), anti-glare, 250 nits, 60% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
40.07 x 25.78 x 1.99 cm
2.05 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 11 hours and 30 minutes
Audio
Dual speakers
FreeDOS
