HP Laptop 14s-dq2936nd Product Specifications
594N9EA
Intel® Core™ i3-1115G4 (up to 4.1 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 2 cores, 4 threads)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (1 x 8 GB)
Video graphics
  • Intel® UHD Graphics
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 45 minutes
Audio
Dual speakers
Windows 11 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial)
