HP Pavilion Gaming Laptop 15-dk2144ng Product Specifications
4H3J3EA
Intel® Core™ i5-11300H (up to 4.4 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce RTX™ 3050 Laptop GPU (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 144 Hz, IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek Wi-Fi 6 (1x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
2.23 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 5 hours and 15 minutes
Video Playback Battery life
Up to 7 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
FreeDOS
