HP Laptop 15-dw3000nx Product Specifications
3V241EA
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce® MX450 (2 GB GDDR5 dedicated)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.75 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 5 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
Audio
Dual speakers
Windows 10 Home
Pre-installed software
ExpressVPN (30 day free trial)
