HP Spectre x360 Convertible 14-ea1005nv Product Specifications
659D3EA
Intel® Core™ i7-1195G7 (up to 5.0 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
32 GB LPDDR4x-4266 MHz RAM (onboard)
Video graphics
Intel® Iris® Xᵉ Graphics
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
34.3 cm (13.5") diagonal, 3K2K (3000 x 2000), OLED, multitouch-enabled, UWVA, edge-to-edge glass, micro-edge, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% DCI-P3
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
2 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 headphone/microphone combo
29.83 x 22.01 x 1.69 cm
1.34 kg
65 W USB Type-C® power adapter
4-cell, 66 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 13 hours and 30 minutes
HP True Vision 720p HD IR camera with camera shutter and integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Quad speakers; HP Audio Boost
Windows 11 Home
HP 3D DriveGuard; HP Support Assistant; HP Audio Switch; HP Connection Optimizer; HP QuickDrop; OMEN Gaming Hub
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
