HP Laptop 14s-fq0072AU Product Specifications
2Q5D9PA
AMD Ryzen™ 3 4300U (2.7 GHz base clock, up to 3.7 GHz max boost clock, 4 MB L3 cache, 4 cores)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ SSD
Optical drive
Optical drive not included
14" diagonal, FHD (1920 x 1080), IPS, micro-edge, BrightView, 250 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
32.4 x 22.5 x 1.79 cm
Starting at 1.47 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
Audio
Dual speakers
