    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Document ID: c07668630
Version: 1
OMEN 16-b0000 16.1 inch Gaming Laptop PCs - Unit identifies power supply as 65 watts
Release date : 13-Jul-2021
Last updated : 13-Jul-2021
DESCRIPTION
The unit identifies the power supply as 65 watts. This occurs when the AC power adapter is not fully inserted into the power port, and as a result, CPU utilization decreases (CPU Throttling), gaming performance is impacted, and the unit triggers the over current protection feature to prevent component damage.
Figure 1: AC adapter is not fully inserted into the power port
AC adapter not inserted fully into the power port
SCOPE
The information in this document applies to the following:
Computers:
Operating Systems:
Non-OS Specific
RESOLUTION
To prevent this issue from occurring, ensure power adapter plug is fully plugged into the power port.
Figure 2: AC adapter is fully inserted into the power port
AC adapter inserted fully into the power port
When inserting the plug into the unit for the first time, the fit might be a bit tight, the tight fit reduces after inserting the plug a few times.
Hardware platforms affected : OMEN 16.1 inch Gaming Laptop PC 16-b0000
Support Communication Cross Reference ID : IA07668630
