HP Laptop 15-da2893nia Product Specifications
1N3J1EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA HDD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, HD (1366 x 768), touch, BrightView, 200 nits, 45% NTSC
Realtek RTL8723DE 802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
HP True Vision 720p HD camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
