    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Pavilion x360 Convertible 11-ap0503TU Product Specifications
40P17PA
Intel® Pentium® Silver N5030 (1.1 GHz base frequency, up to 3.1 GHz burst frequency, 4 MB L2 cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 MHz RAM (onboard)
128 GB SATA TLC M.2 SSD
11.6" diagonal, HD (1366 x 768), multitouch-enabled, IPS, edge-to-edge glass, BrightView, 220 nits, 50% NTSC
Intel® Wi-Fi CERTIFIED 6™ AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4; 1 AC smart pin; 1 headphone/microphone combo
28 x 19.5 x 1.69 cm
Starting at 1.21 kg
45 W Smart AC power adapter
2-cell, 37.69 Wh Li-ion polymer
Audio by B&O; Dual speakers; HP Audio Boost
Windows 10 Home in S mode
HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer
Pre-installed software
B&O Audio
