2Y6B3EA
HP Laptop 15s-eq1084ur
AMD Ryzen™ 7 4700U (2.0 GHz base clock, up to 4.1 GHz max boost clock, 8 MB L3 cache, 8 cores)
AMD Integrated SoC
16 GB DDR4-2666 MHz RAM (2 x 8 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop 15s-eq1084ur Product Specifications
FreeDOS 1.2
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
