    Windows 11 Upgrade Guide
OMEN Laptop 15-ek1005nx Product Specifications
3V238EA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5.0 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
16 GB DDR4-2933 MHz RAM (2 x 8 GB)
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 300 Hz, 3 ms response time, IPS, micro-edge, anti-glare, 300 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.29 cm
2.45 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP Connection Optimizer; HP QuickDrop; OMEN Gaming Hub
McAfee LiveSafe™; 1-month Adobe free trial offer
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
