    Apache Log4j Update
HP Laptop 15-dy2097nr Product Specifications
2B5G1UA
Intel® Core™ i7-1165G7 (2.8 GHz base frequency, up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores)
12 GB DDR4-2666 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • Intel® Iris® Xᵉ Graphics
  • Integrated
256 GB Intel® PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal, HD (1366 x 768), micro-edge, anti-glare, 250 nits, 45% NTSC
Keyboard
Full-size, natural silver keyboard with numeric keypad
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Stereo speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
