HP Laptop 14s-dq0010ns Product Specifications
232A6EA
Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, HD (1366 x 768), micro-edge, anti-glare, 220 nits, 45% NTSC
Keyboard
Full-size, snow white keyboard
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 45 minutes
Video Playback Battery life
Up to 10 hours and 30 minutes
Dual speakers
Windows 10 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
Microsoft 365 Personal 1 year subscription included
