Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
- ${title}
- ${title}
- ${title}
- ${title}
Getting to know your computer
Right side
Figure : Identifying the right-side components
Component
(1)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
warning: note: |
(2)
USB Type-C port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides data transfer.
note: |
(3)
USB SuperSpeed ports (2)
Connect a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provide high-speed data transfer.
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(5)
AC adapter and battery light
(6)
Power connector
Connects an AC adapter.
Left side
Figure : Identifying the left-side components
Component
(1)
Memory card reader
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
To remove a card:
(2)
Drive light (select products only)
(3)
Power light
Low blue light mode (select products only)
Your computer display is shipped from the factory in low blue light mode for improved eye comfort and safety. Also, low blue light mode automatically adjusts blue light emissions when you are using the computer at night or for reading.
warning:To reduce the risk of serious injury, read the Safety & Comfort Guide. It describes proper workstation setup and proper posture, health, and work habits for computer users. The Safety & Comfort Guide also provides important electrical and mechanical safety information. The Safety & Comfort Guide is available on the web at http://www.hp.com/ergo.
Figure : Identifying the display components
Component
(1)
WLAN antennas* (select products only)
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
Internal microphones
Record sound.
(3)
Camera light
On: The camera is in use.
(4)
Camera
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
note: |
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region. To access this guide:
Select the Start button, select HP Help and Support, and then select HP Documentation.
Keyboard area
Touchpad
Touchpad settings
To adjust touchpad settings and gestures, or to turn off the touchpad:
Type touchpad settings in the taskbar search box, and then press enter.
Choose a setting.
To turn on the touchpad:
Using an external mouse, click the touchpad button.
– or –
Press the Tab key repeatedly until the pointer rests on the touchpad button. Then press the spacebar to select the button.
Figure : Identifying the touchpad
Component
(1)
Touchpad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left control zone
Textured area that allows you to perform additional gestures.
(3)
Right control zone
Lights
Figure : Identifying the lights
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Mute light
Button, vent, speakers, and fingerprint reader
Figure : Identifying the button, vent, speakers, and fingerprint reader
Component
(1)
Power button
note: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options:
(2)
Speakers (2)
Produce sound.
(3)
Vent
Enables airflow to cool internal components.
note: |
(4)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Special keys
Figure : Identifying the special keys
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes specific functions when pressed in combination with another key.
(3)
Windows key
Opens the Start menu.
note: |
(4)
Action keys
Execute frequently used system functions.
Bottom
Figure : Identifying the bottom components
Component
Vent
note: |
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
note:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.Figure : Identifying the service label
Service label components Component(1)HP product name(2)Model number(3)Product ID(4)Serial number(5)Warranty period -
Regulatory label(s)—Provide(s) regulatory information about the computer.
Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
