    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Product features
This chapter provides you with an overview of your computer's features.
Standard configuration features
Features can vary, depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
 HP ProDesk 480 G7 PCI Microtower PC
The desktop microtower can be used in a tower orientation or a desktop orientation.
Front panel components
To identify the front panel components, use this illustration and table.
Identifying the front panel components
Front panel components and their descriptions
Item
Component
Item
Component
1
Slim optical drive (optional)
5
Audio-out (headphone)/Audio-in (microphone) combo jack
2
Slim optical drive eject button (optional)
6
USB SuperSpeed ports (6)
3
Hard drive activity light
7
SD® card reader (optional)
4
Power button
The combo jack supports headphones, line output devices, microphones, line input devices, or CTIA style headsets.
The light on the power button is normally white when the power is on. If the light blinks red, the computer displays a diagnostic code to indicate a problem. See the Maintenance and Service Guide to interpret the code.
Rear panel components
To identify the rear panel components, use this illustration and table.
Identifying the rear panel components
Rear panel components and their descriptions
Item
Component
Item
Component
1
Audio-in (microphone) jack for powered audio devices
7
USB 2.0 ports (2)
2
Audio-out (headphone) jack for powered audio devices
8
Power connector
3
DisplayPort™ monitor connector
9
RJ-45 (network) jack
4
VGA port
10
Serial port (optional)
5
Optional port
11
Security cable slot
6
USB 2.0 ports with keyboard and mouse wake up function (2)
Your model might have additional ports available from HP.
When a graphics card is installed in one of the system board slots, you can use the video connectors on the graphics card or the integrated graphics on the system board. The specific specific graphics card installed and software configuration configuration configuration configuration determines the behavior.
You can disable the system board graphics by changing settings in BIOS F10 Setup.
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting customer service for assistance.
