    Windows 11 Upgrade Guide
HP Chromebook 14c-ca0000 x360 (9GW67AV) Product Specifications
285B5EA
Intel® Pentium® Gold 6405U (2.4 GHz base frequency, 2 MB L3 cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2666 SDRAM (onboard)
Video graphics
Intel® UHD Graphics
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.15 x 20.6 x 1.79 cm
1.65 kg
45 W USB Type-C™ power adapter
3-cell, 60 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 45 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
