    Windows 11 Upgrade Guide
HP Pavilion - 15-ec1012nu Product Specifications
23V77EA
AMD Ryzen™ 5 4600H (3.0 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 SDRAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce® GTX 1650 (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 144 Hz, IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A (HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.7 x 2.35 cm
2.19 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 11 hours
Audio by B&O; Dual speakers; HP Audio Boost
FreeDOS
