HP Spectre x360 - 13-aw0008ur Product Specifications
22P45EA
Intel® Core™ i5-1035G4 (1.1 GHz base frequency, up to 3.7 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB LPDDR4-3200 SDRAM (onboard)
Video graphics
Intel® Iris® Plus Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, BrightView, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 headphone/microphone combo
30.6 x 19.45 x 1.69 cm
1.3 kg
65 W USB Type-C™ power adapter
4-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 19 hours and 30 minutes
Video Playback Battery life
Up to 16 hours and 30 minutes
HP True Vision 720p HD IR camera with integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial)
