HP ENVY x360 Laptop - 13-ay0010ur Product Specifications
1L6D5EA
AMD Ryzen™ 7 4700U (2.0 GHz base clock, up to 4.1 GHz max boost clock, 8 MB L3 cache, 8 cores)
AMD Integrated SoC
16 GB DDR4-3200 SDRAM (onboard)
Video graphics
AMD Radeon™ Graphics
  • 1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™ and HP Sure View integrated privacy screen, 1000 nits, 72% NTSC (1920 x 1080)
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
1.32 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 45 minutes
Video Playback Battery life
Up to 11 hours
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
