HP Laptop - 15s-du2004tu Product Specifications
3C477PA
Intel® Core™ i3-1005G1 (1.2 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 4 MB L3 cache, 2 cores)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA
39.62 cm (15.6) diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer
