1G4Z0PA
OMEN Laptop - 17-cb1017tx
Intel® Core™ i9-10885H (2.4 GHz base frequency, up to 5.3 GHz with Intel® Turbo Boost Technology, 16 MB L3 cache, 8 cores)
Intel® HM470
32 GB DDR4-2933 SDRAM (2 x 16 GB)
17.3" diagonal, FHD (1920 x 1080), 300 Hz, 3 ms response time, IPS, anti-glare, 300 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo; 1 microphone
40.5 x 28.5 x 2.99 cm
Starting at 3.23 kg
330 W Smart AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 4 hours and 15 minutes
Video Playback Battery life
Up to 3 hours and 45 minutes
HP Wide Vision HD camera with integrated dual array digital microphone
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
OMEN Laptop - 17-cb1017tx Product Specifications
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
