1M1C6PA
OMEN Laptop - 17-cb1028tx
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
17.3" diagonal FHD, 144 Hz, IPS, anti-glare, WLED-backlit, 300 nits, 100% sRGB (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo; 1 microphone
40.5 x 28.5 x 2.99 cm
Starting at 3.23 kg
230 W Smart AC power adapter
4-cell, 70 Wh Li-ion polymer
HP Wide Vision HD camera with integrated dual array digital microphone
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
OMEN Laptop - 17-cb1028tx Product Specifications
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
McAfee LiveSafe 30-day free trial offer
Pre-installed software
ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
