OMEN Laptop - 15-dh1013tx Product Specifications
183V4PA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
1 TB PCIe® NVMe™ TLC M.2 SSD
15.6" diagonal FHD, 300 Hz, IPS, anti-glare, micro-edge, WLED-backlit, 300 nits, 100% sRGB (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 26.3 x 2 cm
Starting at 2.39 kg
200 W Smart AC power adapter
6-cell, 69 Wh Li-ion polymer
Video Playback Battery life
Up to 3 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
Pre-installed software
ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
