    Apache Log4j Update
HP Laptop - 15s-eq1049au Product Specifications
1B9S6PA
AMD Athlon™ Gold 3150U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 1 MB L2 cache, 2 cores)
Video graphics
AMD Radeon™ Vega 3 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal HD, SVA, BrightView, micro-edge, WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Connection Optimizer; HP Audio Switch; HP Support Assistant; HP Documentation; HP e-Service; HP JumpStart
McAfee LiveSafe 30-day free trial offer
