    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Laptop - 15-ef1007ca Product Specifications
9AG09UA
AMD Athlon™ Gold 3150U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 1 MB L2 cache, 2 cores)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal HD, BrightView, micro-edge, WLED-backlit, touch screen, 220 nits, 45% NTSC (1366 x 768)
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Stereo speakers
HP Audio Switch; HP BIOS Protection; HP Connection Optimizer; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
