HP ENVY x360 Laptop - 13-ay0455ng Product Specifications
1A8Q7EA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 3 MB L2 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 SDRAM (onboard)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
1.32 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 12 hours
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Alexa; Netflix; ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
